nufcmichael Posted January 27, 2007 Posted January 27, 2007 Hello all, Just 3 quick questions, I have an ultima 4 zone control panel fitted in my new home. Can I simply change the control panel and keep existing wiring as I only have one exit with a delay? Can I change my pir sensor with another simlilar as it rarely picks anyone up.(are they all the same wiring, can I buy any) ? Are all door contacts the same wiring as well? As I would like to renew them as well. Any help would be greatfull , Thank You!!!!!!
Guest Posted January 27, 2007 Posted January 27, 2007 Hello all,Just 3 quick questions, I have an ultima 4 zone control panel fitted in my new home. Can I simply change the control panel and keep existing wiring as I only have one exit with a delay? Can I change my pir sensor with another similar as it rarely picks anyone up.(are they all the same wiring, can I buy any) ? Are all door contacts the same wiring as well? As I would like to renew them as well. Any help would be greatfull , Thank You!!!!!! 1. Yes 2. Yes 3. Yes As long as you understand the basics its relatively easy to do. Remember high voltage is present in the panel and you should take extreme caution when opening such devices.
camerabloke Posted January 27, 2007 Posted January 27, 2007 dont depend on turning the fuse off, use a meter and test for no voltage then prove it on a known live source. IF YOU ARE NOT COMPETENT, THEN DO NOT TOUCH IT Eucam Security Systems 0845 4630 746 www.eucam.co.uk
