Reson8 To Galaxy 2-20 Connections
I have a Honeywell Galaxy 2-20 panel with the following connections:
Bell+12V, 0V, T, (Picture of a bell), (Picture of a sun - presumably strobe)
I have 2 ADE Reson8 bell boxes with the following connections:
RTN-, Hold Off+, Hold Off-, Trig -, STB -
Does anybody know how I should connect the bellboxes to the panel please?
  simonw said:
Thanks for the reply djrock.
I've never worked on a Galaxy panel before either. I also have an idea of how to wire the bells but I'm not sure and would certainly value a second opinion. I'm slightly perplexed because I bought the Reson8 bells specifically for this job as I thought they would be compatible with the panel (they are now a Honeywell product - taken over from ADE) but unfortunately they still have the old ADE packaging and associated wiring convention.
I have everything else installed - this is the only thing that's holding me up.
Could you give the advice privately outside the forum?
Can anyone else help?
ps I would call Honeywell but their technical advice line isn't available at weekends, and I was really hoping to get this sorted today.
Many on here would make you believe thst having eng info is subject to you being "trade" and MUST be an approved installer.
Wrong
Just look on ebay, every book ever made
Wrong
I find it really strange you know you would'nt do your own dentrestory work so why would you leave your own security to chance????? :whistle:
Standard (not really helpful) reply number 5628! Yawn...... :realmad:
PS Dentistry?
