Guest ali Posted February 26, 2004 Posted February 26, 2004 Our veritas v8 is 3 and a half years old and h recently started going off when not set. It occasionaly makes very short high pitched alarms when unset too. Any ideas?
gooner31 Posted February 26, 2004 Posted February 26, 2004 might be an idea to get a local alarm company in to give the alarm a service battery could well need changing any problems they find whilst doing the service they will let you know about. pete B) pete ................. Any comments/opinions posted are my own and not that of my employers.
Guest MarkP Posted February 27, 2004 Posted February 27, 2004 It occasionaly makes very short high pitched alarms when unset too. Any ideas? Are you sure it's not a battery powered smoke detector making the short high pitched alarms? Smoke detectors tend to bleep about once a minute when the battery is running low. Some smoke detectors also bleep due to cooking fumes as a pre-alarm (ie before going into the full alarm condition). The Veritas panel certainly shouldn't be emitting occaisional short high pitched alarms - are there any LEDs lit on the panel when the alarm sound occurs? MarkP
Guest dale Posted February 27, 2004 Posted February 27, 2004 It does sound like a smoke detector, we seem to be getting many of these, mebe we should have a frequently asked questions section for "My alarm is making a high pitch short beep". D
Service Engineer Posted February 27, 2004 Posted February 27, 2004 Wanna write one up then Dale ? ........................................................ Dave Partridge (Romec Service Engineer)
