Fitting Informa
bellringer
I am going to install an informa speech dialer a a customers house and place of work, the house is fine as i have mainly done domestics but the works one has a PABX now my understanding of this is just put a 9 in front of telephone number are ther any other issues i may encounter?
Should be as simple as adding a line access number.
Add a pause after the line access number as some PBX's will miss the digits as it's hunting for a line. You could even reserve a line for the dialler and give it its own line access number or set the routing in the PBX.
The other issue you may encounter is finding a spare analogue port on the system.
I urge caution, i know i hate diallers but if you run anything through a pbx, what happens when the power is off?
That's the other thing I meant to mention. It was in the brain but never got as far as the fingers!
ahh the limitations of youth :lol:
