Advice On....
been asked today by a cleint if know anything about plant monitoring, which my answer goes tech alarm on a spare channel, :whistle:
so do you chaps know any better, want to know 3 things high temp (over 16 degress) low temp (less than 1degree) & mains fail all for a server room, tells me the kit does not have a relay ouputs so requires a stand alone set up?
the clients advises me stand alone units are available for this sort of thing with a built in sim card????
any advice / links posted or pm'ed welcome
SD2 with a monitored PSU?
SD2 has 2 outputs, they can be programmed for High and Low Temperatures, wire those into 2 of its own inputs and wire the mains fail from the PSU into another input.
It'll need a phone line though.
great minds ect...... I was thinking speech dialer, but if the power fails there will be no line to dial out on??
mentioned he can buy something off the shelf for a grand to do the biz, I've never heard of anything being a mere alarm monkey :whistle:
How so? battery in psu.
Might be on a PABX, re other thread power fail lines gone.
Get a Galaxy and use sms on a direct line. Saying that a SD2+ will do the same.
cheers
:hmm: as far as i understand there is no proper lines in the building only stuff for the computers
Something like this...
http://www.sendtech.co.uk/index.shtml
sd3 is gsm based
from the pdf
An SD3 can communicate via a PSTN line, a GSM network or via both together. In this instance, the user can
select which connection should dial out first. The unit is fully self-programmable letting you enter up to ten contact
telephone numbers, select the type of message (voice or SMS text) which should go to each and allowing you to
store spoken or text messages created to suit your specific requirements.
The programmable remote access feature lets you dial into the unit via fixed land line or mobile phone from anywhere
in the world, and access four programmable outputs that can remotely switch electrical apparatus or switch on
indicators for a wide variety of technical information signals. An integral thermometer can be pre-set at any given
temperature from 0
menvier? (not on the web site)
Removed Yes its menvier
