Pc Cctv Card
luggsey
At home I have got an el-cheapo Grand-X DVR PCI card with four inputs. I have realised that if I use cameras of a different make I get a sort of pulsing effect on the video of the next camera, if I use two cameras of the same make it seems fine. I set it to PAL N which seems to work fine for the two colour bullet cameras I use but if I add a cheap and nasty Microtec camera it screws the other one up. So I know how to avoid the problem, I know a more expensive setup will work better blah blah. What I would like to know is "what" is happening to cause this effect?
My Amateur Radio Forum
i assume its a single chip card? and if so you have set all the same ie pal colour res etc?
One thing to not is that some cheapy cameras dont output a clean signal (not 1v p-p) and can screw el cheapo kit up
Yes , Yes and Yes!
Thing is they all work ok as a "pair" but not a mix??
i can only assume there is something nasty or upi have a dodgy input. your cam hasnt got any so called enhancement options on it that just amps the main vid signal higher than 1 v. You can also try fitting a 75 ohm terminator to the spare input (or make one)
Good point! Hadn't thought if trying that....
I'm not able to access all the bits and bobs I used to have at work.. :whistle:
Is it just a 75 ohm resistance brigded out?
that will do but it isnt perfect, but just put a 75 ohm resistor across it
I'll start digging the junk box tommorow! :signthankspin:
Hi.
The UK standard is PAL-I (thats an i, not a numeric 1)
Please try this setting.
The main difference is the audio sub carrier but I think the colour sub carrier may also be different on PAL N to I.
Paul.
System Q Ltd.
Hi.
Paul.
Hi, yes already tried that, the setting that includes "I" also includes BDGH as well. Double checked it and it made no difference. I did go through every mode combination when I set it all up, seems to be the el'cheapo microtec camera that screws it all up!
