breff Posted February 2, 2007 Share Posted February 2, 2007 Video of me spraying smoke into 3m length of 20mm tube then blowing it with my mouth at smoke head?????? Will that do? The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
Guest Posted February 2, 2007 Share Posted February 2, 2007 Video of me spraying smoke into 3m length of 20mm tube then blowing it with my mouth at smoke head??????Will that do? No because i have seen that pic and its a rate of rise detector! Link to comment Share on other sites More sharing options...
breff Posted February 2, 2007 Share Posted February 2, 2007 I use my hairdryer on them, I stopped needing it for my hair years ago. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
Guest Posted February 2, 2007 Share Posted February 2, 2007 I use my hairdryer on them, I stopped needing it for my hair years ago. lol, got the hairdryer the solo wont trip some of the higher rated fixed heads. Link to comment Share on other sites More sharing options...
Guest Posted February 2, 2007 Share Posted February 2, 2007 So would that be a sign that the sensor is faulty?.......... Isn't that the idea of doing the test? yep, you ever seen the solo activate a fixed 100. Have played with them to make sure. With dryer and thermometer i know for sure. Link to comment Share on other sites More sharing options...
Guest Posted February 2, 2007 Share Posted February 2, 2007 Just checking.... Good you can be my referee for fire then Link to comment Share on other sites More sharing options...
Chorlton Posted February 2, 2007 Share Posted February 2, 2007 I dont want to be rude but, how come you are a 'Trade Full Member' then??? You do get other types of alarms you know... and I can't get out of intruder trade section it's all one. Sorry if that makes you all mate! Chris. ADMIN EDIT: Chris has full trade access, because some of his business activities run into secitions of the forum, that just being "Fire" wouldn't allow him access too - Its just the way the member catagories work sometimes. Link to comment Share on other sites More sharing options...
uski Posted February 25, 2007 Share Posted February 25, 2007 "Bad DIY can seriously devalue your home" Sure, but good DIY can do a lot better than what a bad installer can do (just kidding, I'm not looking for trouble ) Link to comment Share on other sites More sharing options...
