RickStevens Posted February 4, 2007 Share Posted February 4, 2007 Hi Im ne to this so please forgive if this is a stupid question. I have a home CCTV system that connects via scart to a vcr, however I'm bored of putting tapes in it every 8 hours and want to upgrade to a time lapse recorder. I have read a previous post here about Scart to BNC, but just wondered if the following is possible. Connect the CCTV to a VCR via aux in. Alter a standard TV ariel cable so that one end had a BNC connector, and connect from the TV out on the VCR directly to the BNC input on the time lapse recorder. Would this work? thanks Rick Link to comment https://www.thesecurityinstaller.co.uk/community/topic/15424-tv-ariel-and-bnc/ Share on other sites More sharing options...
camerabloke Posted February 4, 2007 Share Posted February 4, 2007 yep, but instead of video why not digital hard drive? Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment https://www.thesecurityinstaller.co.uk/community/topic/15424-tv-ariel-and-bnc/#findComment-148615 Share on other sites More sharing options...
RickStevens Posted February 4, 2007 Author Share Posted February 4, 2007 I'm trying to keep costs down for the time being. I can pick up a 24hr time lapse video on E-Bay (yeah i know!) for Link to comment https://www.thesecurityinstaller.co.uk/community/topic/15424-tv-ariel-and-bnc/#findComment-148618 Share on other sites More sharing options...
Guest Posted February 4, 2007 Share Posted February 4, 2007 HiIm ne to this so please forgive if this is a stupid question. I have a home CCTV system that connects via scart to a vcr, however I'm bored of putting tapes in it every 8 hours and want to upgrade to a time lapse recorder. I have read a previous post here about Scart to BNC, but just wondered if the following is possible. Connect the CCTV to a VCR via aux in. Alter a standard TV ariel cable so that one end had a BNC connector, and connect from the TV out on the VCR directly to the BNC input on the time lapse recorder. Would this work? thanks Rick That won't work as the TV Out on the VCR is UHF (Ultra High Frequency, TV Signal if you like) and then you would be putting that into a composite input on a time lapse, the time lapse won't have a UHF to composite converter like a domestic VCR. You need to take the composite camera picture on the scart straight into the time lapse input, you can cannibalize the one end of the scart to put a BNC on if you want to keep costs down. Wire from the time lapse output into a spare aux input on the TV leaving your other VCR out of the loop. Dave Link to comment https://www.thesecurityinstaller.co.uk/community/topic/15424-tv-ariel-and-bnc/#findComment-148621 Share on other sites More sharing options...
Service Engineer Posted February 4, 2007 Share Posted February 4, 2007 Alter a standard TV ariel cable so that one end had a BNC connector, and connect from the TV out on the VCR directly to the BNC input on the time lapse recorder. Would this work? NO, It wouldn't, the tv out of the vcr will be on a very wide signal in the uhf bands (440-880Mhz), the video in on a time lapse vcr will be expecting a very narrow signal on a frequency around (17-20 Mhz). ........................................................ Dave Partridge (Romec Service Engineer) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/15424-tv-ariel-and-bnc/#findComment-148622 Share on other sites More sharing options...
RickStevens Posted February 4, 2007 Author Share Posted February 4, 2007 That won't work as the TV Out on the VCR is UHF and then you would be putting that into a composite input on a time lapse. You need to take the composite camera picture on the scart straight into the time lapse input. Wire from the time lapse output into a spare aux input on the TV leaving your other VCR out of the loop.Dave There are some cable kits on the maplin website that will convert scart to numerous other connections including BNC, but I would end up with 2 BNC connectors to connect. I assume 1 BNC would be for video and the other for audio. Could I use one of those kits to do what you suggest? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/15424-tv-ariel-and-bnc/#findComment-148623 Share on other sites More sharing options...
Guest Posted February 4, 2007 Share Posted February 4, 2007 That won't work as the TV Out on the VCR is UHF (Ultra High Frequency, TV Signal if you like) and then you would be putting that into a composite input on a time lapse, the time lapse won't have a UHF to composite converter like a domestic VCR. You need to take the composite camera picture on the scart straight into the time lapse input, you can cannibalize the one end of the scart to put a BNC on if you want to keep costs down. Wire from the time lapse output into a spare aux input on the TV leaving your other VCR out of the loop.Dave This should help click here or this on ebay. Watch out for what type of connecter you need for the scart bit ie: male or female. Dave Link to comment https://www.thesecurityinstaller.co.uk/community/topic/15424-tv-ariel-and-bnc/#findComment-148627 Share on other sites More sharing options...
Guest Posted February 4, 2007 Share Posted February 4, 2007 yep, but instead of video why not digital hard drive? Shame on you, a "Camerabloke" as well Dave Link to comment https://www.thesecurityinstaller.co.uk/community/topic/15424-tv-ariel-and-bnc/#findComment-148628 Share on other sites More sharing options...
RickStevens Posted February 4, 2007 Author Share Posted February 4, 2007 This should help click hereor this on ebay. Watch out for what type of connecter you need for the scart bit ie: male or female. Dave I Dont understand how the cable on ebay fits in? The timelapse recorders I've seen had 1 BNC input for Audio and 1 for video. I assume that I need some sort of gender changer to connect the CCTV camera scart socket into the one on this cable, whats the other BNC for? Sorry for being thick! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/15424-tv-ariel-and-bnc/#findComment-148630 Share on other sites More sharing options...
Guest Posted February 4, 2007 Share Posted February 4, 2007 I Dont understand how the cable on ebay fits in? The timelapse recorders I've seen had 1 BNC input for Audio and 1 for video. I assume that I need some sort of gender changer to connect the CCTV camera scart socket into the one on this cable, whats the other BNC for?Sorry for being thick! You would need to connect your scart from your camera into the scart end (you may need a gender changer, I have never played with scarted cameras before). The BNC marked video out would then go into the time lapse in video in. You would need a second lead to go from time lapse video out to TV using the opposite BNC. I would just get a standard scart lead and chop one end of. Using the pinouts I have given you connect a BNC sheath to ground and the centre pin to video in or out depending which way you are going. Saying that a standard scart may cost you in excess of what the convertor costs on ebay. Rule of thumb is simple, avoid any TV aerial connections. The output from your camera is composite video, the inputs on a time lapse are composite video and the aux scart or phono inputs on your TV are composite video. You just need to source leads to go from camera to time lapse to TV. Hope that helps Dave Link to comment https://www.thesecurityinstaller.co.uk/community/topic/15424-tv-ariel-and-bnc/#findComment-148633 Share on other sites More sharing options...
