entry/exit time on the veritas 8
Guest Guest_mike
Guest Guest_mike
how do i change the entry/exit time on the veritas 8
It can only be changed from engineers mode
Guest Guest_mike
that i guessed fitted the alarm myself but i do not have access to the engineering manual?
Unfortunately this site no longer gives out engineering manuals, unless you are in the trade and can prove it.
Try contacting customer services at Texecom Website they will be able to assist you further.
Colin.
