Sd1+ And Broadband
robfountain
hi folks,
i've got an sd1+ linked into my control panel - however, when i hard wire it up to an extension phone socket, the broadband goes off.
I'm assuming this is because it's not filtered (although there's no mention of it anywhere in the guides).
What's the best option - fit a bt plug on the end and then use a standard filter into the front of the extension socket or get a broadband phone socket and hard wire into that?
cheers
Hard wiring is always going to be better than plug-in.
