jezf Posted February 6, 2007 Posted February 6, 2007 regarding the galaxy g2 alarm, is there an add on module available that will enable it to have a menu driven 7 day timer? i know the g3 has this function, but its a lot more expensive!
norman Posted February 6, 2007 Posted February 6, 2007 no Nothing is foolproof to a sufficiently talented fool.
jezf Posted February 6, 2007 Author Posted February 6, 2007 no thanks for your reply. i had a quote from a local alarm company to supply a g2 "automated control panel" to conform with my "special requirements" of a timer, does anyone know what method he may be using to incorporate the timer into the g2?
Service Engineer Posted February 7, 2007 Posted February 7, 2007 add on module available that will enable it to have a menu driven 7 day timer? If you don't mind me asking, what is the timer going to be used for.? And I assume your gonna want to be able to alter/ammend it's on/off/day times.? ........................................................ Dave Partridge (Romec Service Engineer)
jezf Posted February 7, 2007 Author Posted February 7, 2007 If you don't mind me asking, what is the timer going to be used for.? to automatically part set the system at a preset time, and then unset the system at a preset time. can i ask, is it relatively easy for an electrician to wire in a time clock into the g2, even if the software in the g2 does not have it yet.
jezf Posted February 7, 2007 Author Posted February 7, 2007 you need a g3, doing that with a g2 is not the best idea i have heard it may not be the best idea, but is it do-able?!
