Simon_B Posted February 10, 2007 Posted February 10, 2007 It is a newish house i am only one thats lived there - the master socket is in lounge and been unused Is the wiring visible (i.e. standard BT surface-fixed) or hidden under floorboards and chased in etc ? If all hidden, likely to have been installed but the builders, but could be they left it disconnected etc but with a joint through for the extension. Of course might it be that the point is cabled correctly on the working circuit but its a simple as a faulty linejack, perhaps bent pins etc, so the line gets there and extension wires off back ok but no connection to the BT431a plug on the telephone ? Just a few ideas. Simon ToneTel Telecom www.tonetel.co.uk
bellringer Posted February 11, 2007 Author Posted February 11, 2007 Is the wiring visible (i.e. standard BT surface-fixed) or hidden under floorboards and chased in etc ?If all hidden, likely to have been installed but the builders, but could be they left it disconnected etc but with a joint through for the extension. Of course might it be that the point is cabled correctly on the working circuit but its a simple as a faulty linejack, perhaps bent pins etc, so the line gets there and extension wires off back ok but no connection to the BT431a plug on the telephone ? Just a few ideas. Simon The cables are up the outside of house and it looks like the extension is connected from he outside and i have just found that the upstairs doesnt work either only the extension, when we moved in I got the builder to put the extension in and have never used the one where master socket is.?
luggsey Posted February 11, 2007 Posted February 11, 2007 Thank you i will try and get back to you You never did! ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
bellringer Posted February 13, 2007 Author Posted February 13, 2007 You never did! Sorry. i am working away all this week will try when i get home.
luggsey Posted February 13, 2007 Posted February 13, 2007 Sorry. i am working away all this week will try when i get home. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
bellringer Posted February 20, 2007 Author Posted February 20, 2007 I have looked and outside the cables connects to a cable that runs round the house (extension) there looks to be 3 wires from the "mains" that go around the house to the socket that works. how do i connect into the cable to "fire" up the socket in lounge? ta
luggsey Posted February 20, 2007 Posted February 20, 2007 I have looked and outside the cables connects to a cable that runs round the house (extension) there looks to be 3 wires from the "mains" that go around the house to the socket that works.how do i connect into the cable to "fire" up the socket in lounge? ta Sorry if I missed something here? Have you pulled off the front of the BT master socket and tested it yet? Newish house with cables outside? Who did that?? Is there a j-box outside or what? Where are you connecting these 3 wires too? Need more info to help you further Bellman.... ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
Richard Huison Posted February 20, 2007 Posted February 20, 2007 From an X- comms engineer, if you can dial out and hear the lady on the other end and it cuts out, it could well be a fault on the line, or you have exceeded your REN. Try this, and its a useful number for all engineers wanting to test a line. Dial ####, "BT line test facility" Ex directory number removed by mod. AG. If its an X-Directory line you will not get the optiuon for a ringback test, if it is Press 4 and clear down (Hang up) The handset should ring back in 5 seconds. If it doesn't check pins 3 and 4 are punched into the secondary output on the Master. If the problem persists, then its a call to BT, But as previously mentioned, they will charge you, unless your a tall blond who does cash in hand jobs..... Richard www.accesscontrol.ie richard.huison@accesscontrol.ie ACT "Where performance counts" "Is your Access Control system Vista Ready?"
luggsey Posted February 20, 2007 Posted February 20, 2007 From an X- comms engineer, if you can dial out and hear the lady on the other end and it cuts out, it could well be a fault on the line, or you have exceeded your REN. Try this, and its a useful number for all engineers wanting to test a line.Dial *****, "BT line test facility" If its an X-Directory line you will not get the optiuon for a ringback test, if it is Press 4 and clear down (Hang up) Richard Try 1470 ***** (Mods don't like this number in public) this will then give you all options, however I think there is a pin number being used as well sometimes now.... ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
norman Posted February 21, 2007 Posted February 21, 2007 unless your a tall blond who does cash hand jobs.....Richard Nothing is foolproof to a sufficiently talented fool.
