robbiethekid Posted February 10, 2007 Posted February 10, 2007 Hi there, I am a newbee and DIYer (gulp) with a problem on my Texecom Veritas 8C control panel. It is a self install in a private residence and has worked well for a number of years until a series of power cuts came along. This normally had no effect on the system but the last one left the alarm dead to the world, no buttons, sounds, nothing. After a few days it sorted itself out and was totally back ot normal.....til the next power cut. Now it will not stop soundint the internal buzzer at the control panel, only removing the power from the transformer stops the noise! I do note that the battery is still connected and yet the internal buzzer and lights are not activated, new battery perhaps? Or is theis in fact the problem? When I power up again (mains for transfomer) the system starts to arm itself but my code is not accepted and it all ends in tears with the internal sounder going off again. Grrrrrrrr. The green led for UNSET is lit, if this has any bearing on the situation. Anyway, thanks for listening, just glad to get it off my chest...... My name is Robbie and.......I have a problem with my alarm that .......I can't........I can't.......fix myself! There.......I said it phew. Thanks Robbie
camerabloke Posted February 10, 2007 Posted February 10, 2007 sounds lke battery is dead, also you may have caused some damage to the charging circuit , change the batt and see if that helps, if not you may have to source a new panel im afraid Eucam Security Systems 0845 4630 746 www.eucam.co.uk
kka Posted February 10, 2007 Posted February 10, 2007 hi fit a new battery. be aware the codes may be back to factory default. and your alarm may need reprogramming. while inside the panel be aware of the mains supply Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
camerabloke Posted February 10, 2007 Posted February 10, 2007 he knows!!!! hes a DIY er Eucam Security Systems 0845 4630 746 www.eucam.co.uk
amateurandy Posted February 10, 2007 Posted February 10, 2007 ....has worked well for a number of years until a series of power cuts came along.This normally had no effect on the system but the last one left the alarm dead to the world, no buttons, sounds, How many years, and when did you last replace the battery? Several pro's have said that's the most likely cause. There have been many debates here about how often to change batteries, but every 4 years or so seems to be a common figure if you don't have a means of testing them properly. While you're at it, don't forget the bell-box battery - comments I've seen imply they last longer, but..... Hopefully, as you installed it, you know how to work on it safely, still have the manuals and can set it all up again.
robbiethekid Posted February 10, 2007 Author Posted February 10, 2007 Thanks for your comments, I think the common held view is battery duff and panel has reset to factory defaults as well. The battery is about 3-4 years old I would guess, so it probably has done well and needs retired. Someone asked if the external siren went off, answer - no. If it had we would have been auto dialled up, so I am certain that just the internal sounder went off. I'm off to try the 0000 code to see if that works, problem is......where did I put that engineer manual??? I am a DIYer! Forums are great, thanks again. Robbie
robbiethekid Posted February 10, 2007 Author Posted February 10, 2007 It 'aint 0000 I'll contact Texam for a download catalogue. Here's hoping!! Robbie
robbiethekid Posted February 10, 2007 Author Posted February 10, 2007 no 0000 is not the default code, the user default code is CODE REMOVED BY MODERATOR (Alarm Guard) so you may be able to contact texecom for a manual but they may not give you one, im not sure till you speak to them hope this helps cjt Thanks, I have left an email with them for help and access to the engineers instructions, if not I'll have to skip it and get a new panel or system. Best regards Robbie
robbiethekid Posted February 10, 2007 Author Posted February 10, 2007 Sorry we can't help you further Robbie, but we have to be careful about what information we give out as it could effect other people's securityPaul No problem, many thanks to all, I'll let you know how I get on. Ta Robbie
camerabloke Posted February 10, 2007 Posted February 10, 2007 no 0000 is not the default code, the user default code is CODE REMOVED BY MODERATOR (Alarm Guard) so you may be able to contact texecom for a manual but they may not give you one, im not sure till you speak to them hope this helps cjt tut tut colin Eucam Security Systems 0845 4630 746 www.eucam.co.uk
