External Sounder Upgrade For Atg Sx-ivc
jlyall
Hi,
I have got an ATG Thrust SX-IVC alarm system which I know is really old, but works well.
The question that I have is, I want to upgrade the External sounder, to maybe an odyssey 3 with the alternating LEDs and the strobe, so it doesn
  Alarm Guard said:
Could you be mistaken?
Nearly all sab sounders have a 6 volt back up battery, but the supply to them from the panel is 12 volts.
.... so did you think it is 6 volts because you saw the back up battery inside it... or have you some evidence that the supply from the panel is 6 volts?
The Siren Driver for this system, from the Manual, shows 6v
Thanks for your replies.
I pretty sure that the whole pannel is 6v. The control panel battery is also 6v.
The manual recomended, back in the day, a 'Moose MPI-37 , MPI -38 or MPI-11' siren driver for an eternal siren. I dont know if anybody knows these sirens and if they are 6v.
