bellringer Posted February 17, 2007 Posted February 17, 2007 Can the SD1 be installed to the veritas panal if so is it complecated i have only fit the ade informa, and normally stick to them but a customer has 1 given to him and wants its fitting, is it a case of going to the bells on panel - do i need to fit the resister on this panel? Ta
Guest Alarm Guard Posted February 17, 2007 Posted February 17, 2007 Which Veritas panel is it? V8... R8... R8+ ... or Excel
bellringer Posted February 18, 2007 Author Posted February 18, 2007 Which Veritas panel is it? V8... R8... R8+ ... or Excel Will come back to you when i visit this week/Thanks
Guest Alarm Guard Posted February 18, 2007 Posted February 18, 2007 The reason I asked is because with the V8 and R8 you would need to wire it from the bell output, but the R8+ and Excel have dedicated pre-programmed outputs.
bellringer Posted February 22, 2007 Author Posted February 22, 2007 The reason I asked is because with the V8 and R8 you would need to wire it from the bell output, but the R8+ and Excel have dedicated pre-programmed outputs. Sorry but guy has now changed his mind and doesnt want it doing
