markkee Posted February 18, 2007 Posted February 18, 2007 I have a Scantronic 9651 & a Reson8 Bell box can anybody tell me which wire's to connect between the 2 The 9651 has OP1 OP2 OP3 TR + LS 12V AUX 12V AUX 0V 0V The Reson8 has RTN- HOLD OFF + HOLD OFF - TRIG- STB- Thanks for any help
Guest Posted February 18, 2007 Posted February 18, 2007 I have a Scantronic 9651 & a Reson8 Bell box can anybody tell me which wire's to connect between the 2 The 9651 has OP1..........to trig OP2..........to stb- OP3 TR............to rtn- + LS 12V AUX.......to hold off+ 12V AUX 0V................tl hold off- 0V Hope that helps
Guest Posted February 18, 2007 Posted February 18, 2007 Don't use the panel but I guess OP's have to be programmed as reguired eg OP1 to bell & OP2 to strobe? Outputs default to 1 bell 2 strobe.
Guest Posted February 18, 2007 Posted February 18, 2007 Thats the whole point of small G2 panels, if you go with the flow there is virtually no need to reprogramme them. Even the M series is set up for minimal programming .
Guest Posted February 18, 2007 Posted February 18, 2007 Thanks for the quick reply No worries, glad to help.
markkee Posted April 24, 2007 Author Posted April 24, 2007 All works well with 1 Reson8 but i have now brought a 2nd & have wired as per the instruction that came with it but the first does not work. I can only get both to work if i wire both the same back to the Alarm. Any Help? Thanks Mark
Guest anguscanplay Posted April 24, 2007 Posted April 24, 2007 You have to series and parallel the connections. you have to parallel some and series the others http://www.thesecurityinstaller.co.uk/comm...mp;hl=bellboxes
