andyjacklin Posted February 19, 2007 Posted February 19, 2007 My last question (fingers crossed) I have installed all of my Veritas R8 alarm system apart from the external bell box. Will the alarm function correctly without this as I have an internal sounder & wanted to make sure the PIR's were deffinately pet imune before annoying all the neighbours? This is the easiest way I can think of checking it as it obviously needs to be set (I can't ask the cats to do a walk test for me!) and it'll probably be a little while until I get round to fitting the external bell anyway.
camerabloke Posted February 19, 2007 Posted February 19, 2007 it should run fine without an external bell Eucam Security Systems 0845 4630 746 www.eucam.co.uk
kka Posted February 19, 2007 Posted February 19, 2007 yes but leave the little link in, so as not to create a tamper. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
alextheman Posted April 4, 2007 Posted April 4, 2007 Another good way to check put the said PIRS in to soak test the texecom r8 has this compatbilty and will just write activations to the log
Guest anguscanplay Posted April 4, 2007 Posted April 4, 2007 i would be more tempted to programme a very short bell ring time and no rearm for the activated zone just in case there is a break in
mjw Posted April 4, 2007 Posted April 4, 2007 My last question (fingers crossed) I have installed all of my Veritas R8 alarm system apart from the external bell box. Will the alarm function correctly without this as I have an internal sounder & wanted to make sure the PIR's were deffinately pet imune before annoying all the neighbours? This is the easiest way I can think of checking it as it obviously needs to be set (I can't ask the cats to do a walk test for me!) and it'll probably be a little while until I get round to fitting the external bell anyway. As it was said before the panel will work fine if tamper link is fitted in panel...i would deffo fit external bell a.s.a.p as just seeing it is a deterrant and it may mean your neighbourhood burglar goes on next door/street
