Help Installing A Texecom Odyssey 3 Bell Box
Hatsumi
Hello,
I am replacing an old Bell Box with a Texecom Odyssey 3 Bell Box.
Can anyone advise me which wire from the Alarm Control Panel goes to which connection on the Bell Box :unsure:
I have included photo's of the control panel and bell box.
The wires from the control panel that I need help with are as follows:
Strobe + Yellow
Strobe - Green
T (SCB) White
A (SCB) Black
Bell + Red
Bell - Blue
Any help would be very much appreciated cheers
Many Thanks,
Steve.
please confirm that the panel is an optima ?
Guest Alarm Guard
Looks to me like a very early Optima 6
You are both correct, the picture shows my old control panel as I don't have a picture of my new panel which I have replaced it with.
The new panel is a Optima XM XLConcept 6 but has almost the same connections as the old. I bought it for this reason, so that I could take out the old and install a new replacement.
The Bell Box also needed replacing but this is where I am having the problem with identifying where the wires go? :unsure:
Can either of you gentlemen help me please?
Thanks, Steve.
Green to STRB
Black to 0V
White to Tamp
Blue to Bell
Red to +12V
and take the yellow out of the terminal in the control panel and tape it up or cut it off so it can't touch anything else
That's great, I was confused why there was 6 wires from the control panel and only 5 in the Bell Box :)
Just one other question, should the Bell Box have the jumper set to SCB or SAB?
Thanks very much for your time :)
Best Wishes,
Steve.
Why, are your eyes painted on?
* loving the box of quick blows in anticipation!
