Diy Uninstalling
TVC
Hi.
Moved into a new house and it has installed and running a Texecom Veritas R8 alarm with sensors throughout all rooms.
I don't want it so how can I disable it and then safely remove it all? :hmm:
cheers!
Hi.
We cannot give out this sort of information for obvious reasons.
Your best bet would be to call an engineer.
  • 3 weeks later...
Can't you just log in as an Engineer, which will disable the alarm.
Then disconnect the power, and remove the battery.
Then it should just be a case of removing all of the equipment.
This isnt priviledged information. so assuming I am correct I dont think I am defying any moral restrictions.
cheers
