jonnywells Posted February 22, 2007 Posted February 22, 2007 On my C&K 700l the speaker that sounds when you enter/exit is REALLY loud. When Adi came to service my system he tryed to turn the volume down via somthing inside the control box but for some reason it didnt make any difference. Is there anyway i can swap the speaker for somthing i can adjust the volume?
Guest anguscanplay Posted February 22, 2007 Posted February 22, 2007 these panels are well known for the speaker being too loud the only real solution is to swop the existing speaker which is probably rated at 16ohm for one with a higher rating ie "teletone" speaker rated at 55ohms this will reduce the volume a little and give a smoother tone
Adi Posted February 22, 2007 Posted February 22, 2007 Ill look a right tit now,should have asked us to sort it. I really can't be ar**** with it anymore.
Barsnake Posted February 22, 2007 Posted February 22, 2007 the volume on the motherboard only did part set on the 700L you will have to have a resistor fitted in line I always went for a 100ohm Or you could as said swap the speaker for a high ohm'd unit BUT beware dropping the volume on a 700L in either of these ways also drops the alarm volume as well Sorry Adi To Poss Butt In
Adi Posted February 22, 2007 Posted February 22, 2007 No worries mate. I would have done with a VR as i wouldnt know what size ressy to fit. I really can't be ar**** with it anymore.
Guest anguscanplay Posted February 22, 2007 Posted February 22, 2007 omnicrom panels used to have a resistor soldered across them to achieve same effect but seen many of them burned out when panels crashed always ditched the lot
Barsnake Posted February 22, 2007 Posted February 22, 2007 Not Suprised With A AI Omnicrom Fitted Dozens On 700L's Never Had A Problem Hey Adi Have Always Struggled With VR's If You've A Good Version I'd Love A Link, if It Maplins Or RS Say
jonnywells Posted February 22, 2007 Author Posted February 22, 2007 Ill look a right tit now,should have asked us to sort it. Sorry mate, its just one of them things i didnt think about really until after........ 1 of my cats turned up today after you left and i set it and she was went nuts with the noise (although it was funny seeing her go loopy running around!) It dont really matter to much i just thought i ask on here see if any easy solutions. I might just stick some foam in there to quiten it abit
Adi Posted February 22, 2007 Posted February 22, 2007 Sorry mate, its just one of them things i didnt think about really until after........ 1 of my cats turned up today after you left and i set it and she was went nuts with the noise (although it was funny seeing her go loopy running around!) It dont really matter to much i just thought i ask on here see if any easy solutions. I might just stick some foam in there to quiten it abit No worries, ill sort it for you, give us a couple days. I really can't be ar**** with it anymore.
