Guest anguscanplay Posted February 27, 2007 Posted February 27, 2007 yeah i know just get fed up seeing sockets in kids bedrooms conected to shower feeds etc gas is safe if you get it wrong you can smell it going to paint the little ones bedroom that cant be dangerous can it?
Adi Posted February 27, 2007 Posted February 27, 2007 If you want to fit a fcu to ring main or radial lighting circuit, then you could no problems. Now if that over loads the mcb thats a different problem which should have been taken into account. Not getting drawn into tit for tat posts but for arguments sake connecting an alarm panel into a ring main is not going to cause a problem and it would just about never cause a problem on lighting circuit unless a home owner added lots of fancy or shandalier lighting so the circuit was operating at max. I really can't be ar**** with it anymore.
Adi Posted February 27, 2007 Posted February 27, 2007 Have you noticed that in loads of new houses, they are connection the TV aerial booster to the lighting circuit. ... Now that is idle. They could get to a power circuit with ease at that stage. Yes but they use little power possibly the same as a lamp. Providing the circuit has been designed ok its fine. Take a domestic 6 amp mcb with 1.5mm in loft to allow for 50% cable derating for going under insulation and totaling up fittings not to exceed design limit. You get about 14 lamps but obviously things vary and the designer takes different things into account. NOT TRYING TO TEACH PEOPLE HOW TO SUCK EGGS OR WHATEVER THE SAYING IS i shouted it quietly I really can't be ar**** with it anymore.
arfur mo Posted February 27, 2007 Posted February 27, 2007 yep not a problem if i worked in the car industry and wanted to mot cars i would need a cert too whilst ever we fit without liscense then so cant pull joe public over there installs but you can do mobile repairs and all you need is a van and a few spanners - no certs no quals, i'm now off to go do some brakes on a 40 tonner for a bit of cash in hand regs alan If you think education is difficult, try being stupid!!!!
arfur mo Posted February 27, 2007 Posted February 27, 2007 But gas is a special case isn't it. Anyone wrorking on any part of a gas supply system needs to be fuuly competant.But with electric, working on a dis board needs high skills, but anyone with reasonable understanding of electric and able to use tools can be expected to replace a light switch without risking lives. So I can't see electrics getting the corgi treatment for a long time... if ever. gas is treated with righteous caution, yet you can smell it. electric is treated as 'mundane' yet you can't see or smell it. a car is common on our roads and kills most of all, but you can buy vital bits in halfords and fit yourself. go figure? regs alan If you think education is difficult, try being stupid!!!!
arfur mo Posted February 27, 2007 Posted February 27, 2007 yeah i know just get fed up seeing sockets in kids bedrooms conected to shower feeds etcgas is safe if you get it wrong you can smell it going to paint the little ones bedroom that cant be dangerous can it? just don't paint out the gas boiler regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted February 27, 2007 Posted February 27, 2007 best solution now no longer available to most of us part p req point is if we have been having this conversation public should never go into the 240v ac side of an install
arfur mo Posted February 27, 2007 Posted February 27, 2007 i was always taught to put the intruder alarm and any cctv on its own circuit on the none rcd sde of the board if poss as this stops the power been lost if connected to lighting and sockets. cjt i can't knock the theory colin, but this idea also offers less protection to your doughnutt 'in love' engineer as well as the client who decides to swap a battery themselves. regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted February 27, 2007 Posted February 27, 2007 is dohnut allowed as i am not sure whever to be insulted or not would prefer to be know as a muppet
arfur mo Posted February 27, 2007 Posted February 27, 2007 best solution now no longer available to most of us part p reqpoint is if we have been having this conversation public should never go into the 240v ac side of an install as refered to in my pos 3# plus others regs alan If you think education is difficult, try being stupid!!!!
