divettri Posted February 26, 2007 Posted February 26, 2007 It's probably got a tamper, these things won't do anything if a tamper is active, they even appear to have locked up. Clear the tamper then press Reset. Hi, I've just purchased a house fitted with an Accenta 8 Mini system & the previous owners didn't know the code for the system as they never used it. Unfortunately at approx 10:30pm while moving furniture in I knocked the face panel off the number pad & set off the tamper alarm & not having the code the only way I could get the thing to shut-up was to 'snip' the cables feeding the internal & external bells. The strobe continued to flash through the night but I presed 'reset' next day and now 'power' & 'day' are only illuminated. What do I do to reset the system & input my own code? Please HELP!
Guest Posted February 26, 2007 Posted February 26, 2007 I am very sorry but the panel will need defaulting if you don't know the codes, an engineer will need to do this, as we cannot give out defaulting info, an engineer or company on this forum near to you may be able to help
