Security Master Tp800
Mossman
I have had my handbook shredded by the dog and now the alarm is playing up i do not know how to alter it.
Can anyone tell me were to get a handbook from.
Thanks
Hi Mossman, welcome. Please dont make duplicate posts as in this thread http://www.thesecurityinstaller.co.uk/comm...mp;#entry154414
Im sure someone will answer your request soon if they have a copy of the user instructions.
At best you will only get a user manual from this site, so I would recommend that you either contact the original installer or arrange a new one, there is a list below that might be of help alternatively Yellow pages.
I know why it's ringing, it's because i reset the alarm due a wire being broken, i then fixed the wire but had to reset the alarm. but now its gone into a mode were every time you walk into a zone it rings and rings to tell the installer that the zone is working, i can remember from the initial installation the guy reading the manual to turn it off to resume normal operation, so hopefully in theory if i can lay my hands on a manual i will be ok.
Hi , I havent got a manual for that alarm , but it sounds like you have the chime eneabled on a pir zone , look for a key marked CHIME.
Regards.
Regards.
In my quest to beat the alarm, i have tried pressing the chime button, but it only enables it i can never switch it off. ive even now managed to change the timer on the blasted pir so it doesn't immediately chime. it now waits for i think 10 seconds before ringing.
Guest anguscanplay
could we have clarification on the panel please
I would suggest you bite the bullet and get a engineer in to sort it out for you. It sounds like like this is giving you grief that i am sure you could do without.
By pressing buttons you are making things worse - it sounds like you are in some kind of programming mode .
We can try to help & eventually it may work but i would get someone in now if i was you - if only for your sanity
paul
THE BLACK KNIGHT
