basilb Posted February 26, 2007 Share Posted February 26, 2007 Should I be looking at 640*480 resolution for a reasonably clear image from around 20m using a 4-9mm lens? PVR card I'm using defaults to 320*240 which I can upgrade to the higher resolution but will it make a significant difference? I'm finding at the moment that features (e.g. facial) aren't real clear at that distance with the lens in telephoto mode. Thanks. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/16160-what-resolution-for-clearer-image/ Share on other sites More sharing options...
basilb Posted February 27, 2007 Author Share Posted February 27, 2007 This is the card which can do 640*480 given a suitable CPU. http://www.geovision.com.tw/english/product/GV-800.htm The camera is using a Sony EXview 1/3" ccd chip. I'm restricted to 320*240 because of the older P4 processor I'm using but will an ability to use 640*480 make much of a difference? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/16160-what-resolution-for-clearer-image/#findComment-154532 Share on other sites More sharing options...
Guest Posted February 27, 2007 Share Posted February 27, 2007 ...will an ability to use 640*480 make much of a difference? it is four (4) times better than 320x240. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/16160-what-resolution-for-clearer-image/#findComment-154563 Share on other sites More sharing options...
