Gardtec 580
c4rson
Hi everyone. I have a Gardtec 580 alarm system which need the backup battery replaced. The people who fitted it want
Guest anguscanplay
battery mod here
changing the battery will involve removing the panel lid and there is high voltage inside so would always advise leaving to a competant person
i assume the system isnt on maintainance as most firms would cover this kind of thing it may be worth asking another firm to do the job and cover the system for the next year as well
having said that it is a straight foward repair but as you have said the system may activate just make sure you get a replacment battery of the same voltage and current should idealy be 12v 2.8amp
battery mod here
Depends on the current drawn and it can take a 7AH battery.
cheers
Guest anguscanplay
take the old battery with you as can vary in size from 1.2 amps to 7 amps
ten points to the first provable picture of a 580 with a 7amp battery in it
Guest anguscanplay
stood up behind the pcb its probably on of ours
corrected should have said in first post to look at tha old battery first but not to go smaller than2.8amp
I have only ever fitted 7Ah batteries to 580's.
we always fit the bigest batt the panel can hold norm 7Ah (know with new EN that some will take 17AH that aside) is this a wast of a batt or good practice as not a lot in the price from 2.8 to 7.0AH and if saves one call out has been well worth it .
www.AllanMoncrieffAlarms.com
Guest anguscanplay
assuming(dangerous on this site) the op has a normal domestic setup and really that is all i would have used a 580 for
work it out ( please correct my maths)
panel 85ma
bell 30ma
7xpir 80ma
usual iunactivated current drain 195ma divided into 2800 equals 14.3 hours standby alarm current drain 680ma for twenty minutes equals over twelve hours old bs calculation
just cause it fits dont make it the best option
panel would just be charging the battery for harder and longer than neccesary
panel 85ma
bell 30ma
7xpir 80ma
Thats low for pir`s what you use>?
How about a 2nd RKP as well as the on board, a better bell that you are suggesting and 2 x internal sounders.
cheers
Guest anguscanplay
cheers
thats why i asked but staying old school for a moment say a racall appolo only drew 8ma or a optex rx is less than 10ma
if the install had that much gear we would have gone for a 800 series as a different customer really
what i was trying to say to the op was dont just buy the cheap one there really is a minimum size needed
