DarrenB Posted February 28, 2007 Posted February 28, 2007 Hi all, I have just set up a four camera CCTV system which uses X-Vision software for the recording. It works grand for video both live and recorded but has a problem recording sound. Viewing the live video, I can hear the sound OK and it will even be audible using the netwok link on another PC, but try as I might, I cannot get sound on the playback. The video plays back OK but totally silent. I am using an AMD PC with 256 Ram, AC97 onboard audio, XP4SW25 capture board and Win XP home SP2. Any idea's ? Thanks Darren
PeterR Posted February 28, 2007 Posted February 28, 2007 Hi Can you PM me your contact details and I will have an Xvision technician call you tomorrow to see if they can help. Best regards Peter
breff Posted February 28, 2007 Posted February 28, 2007 Slight deviation to topic, but, if you are using xp I would think about upgrading your memory to at least 512mb, ideally more. It probably wont help with your audio problem though. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
DarrenB Posted March 2, 2007 Author Posted March 2, 2007 UPDATE ********* Problem found to be that the schedule needed selecting AFTER the sound option was turned on. I found Y3K to be absolutely brilliant in resolving this issue and can heartily recommend them and their products. Thanks - Darren
Guest anguscanplay Posted March 2, 2007 Posted March 2, 2007 whats x-vision ? worth using in my spare desktop ?
