la2007 Posted March 1, 2007 Posted March 1, 2007 It seems I bought a control panel that connects to all sorts of types of bellbox, and subsequently it can connect to the Texecom bellbox in a number of ways. The Texecom is of the A,B,C,D & S connection type, and the ST6100, well...it appears to be fairly notorious on this forum so I won't list the terminals. I would like to ask the experts here in which manner you would connect the two, for fully functional operation including connection to the Tamper Loop with the PIRs? Thanks In Advance, Si
kka Posted March 1, 2007 Posted March 1, 2007 i am not familiar with this panel can you list the panel connections please, and name the texecom bellbox please. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Adi Posted March 1, 2007 Posted March 1, 2007 i am not familiar with this panel can you list the panel connections please, and name the texecom bellbox please. All texecom ES's are the same. I really can't be ar**** with it anymore.
la2007 Posted March 2, 2007 Author Posted March 2, 2007 The texecom bellbox is as follows: A(12V) Permanent Positive B(BELL) Negative Applied Output to Activate Siren C(TAMP) Negative Removed on Tamper Input D(0V) Permanent Negative S(STRB) Negative Applied Output to Activate Strobe Not exactly sure which model, but as mentioned above they are all the same (Azure, Tempest, Odyssey series) and share the same manual. The ST6100 Melcom connections are as follows: E Earth N/C Normally Closed for AutoDialler Relay COM Relay Common N/O Normally open for AutoDialler Relay Aux 1- Neg supply to PIRs and contacts Aux 1+ Pos supply to PIRs and contacts Max out 250mA SW+ Switched Pos Supply 250mA Max STB+ Latching Strobe Pos Supply STB- Latching Strobe Neg Supply BELL+ Bell Pos Supply BELL- Bell Neg Supply SPK+ Loud Speaker 12v+ SPK- Loud Speaker 12v- AUX 2- Neg Supply for Remote Keypad AUX 2+ Pos Supply for Remote Keypad NETWORK B Remote Keypad data in NETWORK Y Remote keypad data out KEYPAD W Battery supply data out KEYPAD G Mains supply data out SAB 1 OV Self contained bell output normally closed SAB 1 RT Self contained bell output SAB 2 OV Self contained bell output normally closed SAB 2 RT Self contained bell output TAMP tamper loop normally closed Z!-Z6 zone loops normally closed Z7/PA normally closed
