Ad2510 Speech Dialer
I have just bought a AD2510 Speech dialer which is a lynteck there are instructions with the unit
this is what it says
2 wires to phone -no problem
2 wires to 12v + and - no problem
2 wires to "Dry" contact (Normal; open loop. "Trigger"; close loop) NOW this is where my probs start, i have tried to conect to g3 mini and when i connect multi meter on it it pushes out 4.5 volts when i try to connect to D+ and B- the sounder goes of as there is voltage going through the 2 wires.
It says on the box can be activated by NO/NC or VOLTAGE TRIGGERING
i have tried different combinations on the panel and nothing happens if on the "dry wires" i touch the 2 together then it rings my mobile but nothing on the panel
:unsure:
Connect one side to 0v and the other to -bell trigger, when the bell is triggered it will make a closed circuit.
Glad to be of assistance
just wired one up onsite and it wont dial out have tried wiring as you said but it wont dial out, if i disconnect cables it then dials out
on G3 panel i connected 1 wire to B - sounder trigger and 1 to A -0V
They will only go 1 way round as if i put them on the other the outside bell rings.
where i have connected to it looks like a SABX Panel should i leave a gap when dialing!
thanks
Best way really to do this ,is with a relay.
Or alternatively use a different speech dialler, one that takes a pos/neg input. Menvier and Texecom units both do.
