C.Simmons Tech Services Posted March 2, 2007 Share Posted March 2, 2007 I have fitted a camera nearly 500m away from controls and wired cat5 for NVT. I have a normal transmitter and passive reciever. Can I send the telemetry down the coax as usual or is it best to use spare cores for ptz controls, wired direct. From what i've read in the instructions it states it can do up to 300m with normal nvt convertor ether end. The camera is not a dome but a proper ptz baxall reciever/camera/controls Thanx Chris Link to comment Share on other sites More sharing options...
breff Posted March 2, 2007 Share Posted March 2, 2007 I've just looked at NVT's website and it says 225m(750ft) for up the coax. Looksy The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
C.Simmons Tech Services Posted March 2, 2007 Author Share Posted March 2, 2007 Thanx breff but ive been given one of these http://www.nvt.com/products/NV_452R.html at one end and one of these http://www.nvt.com/products/NV_214AM.html at the camera end. The link u found was for using a nv214am at either end Chris Link to comment Share on other sites More sharing options...
breff Posted March 2, 2007 Share Posted March 2, 2007 I think you can only go up the coax on passive baluns look here The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
Garry Posted March 2, 2007 Share Posted March 2, 2007 L.J.Ds transmission is good You can lead a horse to water but you carnt climb a ladder with a bell in both hands. Link to comment Share on other sites More sharing options...
