Scantronic 9800 Error Message
Landlady
Guest Lionel Hutz
Hi, I have a scantronic 9800 alarm installed in a let property. It is showing the following message "Fault" "Service" & "5 r" Obviously it needs servicing but as we don't currently have a service contract does anyone know what the 5 r means so that I can tell the service engineer before they come out in case they need some parts. Also does anyone know of a good firm in the Abingdon/Oxford/Wantage area that doesn't charge enormous sums of money, but is reputable? I have managed to find two that would quote me but seems a lot of money! Thanks :unsure:
Gooners a good lad but if not call Carl Sam at Fortress.
Lenny
hi all,
SR will show if it needs a reset after an alarm or tamper, inserting a valid code may clear it if the tamper has cleared.
a duff battery will be signalled even if not switched on, by a regular actioning of the internal siren from the speakers, and 'bF' desplayed on the keypad (one of the 1st panels to do a routine battery test).
either way, nett result is a competant engineer is still required, just mention what panel it is, and agree a rate of charges before engaging one.
regs
alan
Guest anguscanplay
come on then what have i forgot to mention ( no looking it up )
sr sytem has restarted after total power down
rr reset reqiured
st soak test failed
lb low battery
bf battery fault
tr tamper return
pa panic curcuit activated
c# relevant curciut open
ef exit fault
ea entry alarm
t# relevant tamper open
r# relevant keypad tamper open
rt exess key press
o# flashing relevant curciut omitted
aa/ab/ac area set
e# entry through that # zone
al alarm activated
o# steady operated by that # user
ap aux power fail
same as luggsy not going to garage in rain to see if i have forgotten any
thought i was the battery and eighties panel specialist :P
bf is battery fault..but your right on the rest.. :P
Or When the Customer Rings Up
"We Have A 6 Fault"
A What ?
Guest anguscanplay
"my alarm has gone off when we were in and it says 6F "
no right fine that is bf means you have a flat battery
"no it definatly says 6F"
"its like a t and a n without a line on it "
oh you mean a r
"no a r looks like this R"
no that would be an eight with a line missing wouldnt it
company record twenty six minutes
sr will only show after total power fail on power restore...
correct
rr reset reqiured
st soak test failed
lb low battery
bf battery fault
tr tamper return
ef exit fault
ea entry alarm
rt exess key press
aa/ab/ac area set
al alarm activated
ap aux power fail
one hell of a memeory you've got!!
THE BLACK KNIGHT
rr reset reqiured
st soak test failed
lb low battery
bf battery fault
tr tamper return
ef exit fault
ea entry alarm
rt exess key press
aa/ab/ac area set
al alarm activated
ap aux power fail
straight from the manual...you must be soaked..i mean st :whistle:
Guest anguscanplay
seriously can remember every job from last twenty years names of customer equipment fitted joints made even went back to one after twelve years plus and told them there code number
come to fill in the service sheet at the end of a maintainance visit can i b****r like remember the address never can even when i have looked it up in the book twenty minutes before
plus i still service hundreds of the white boxes
Guest anguscanplay
anyone want to know the programming for a 9100
zone number enter # enter value # = zones not selected will be off in part set
edited by arfur for safety reasons
etc etc
