black knight Posted March 5, 2007 Posted March 5, 2007 anyone want to know the programming for a 9100zone number enter # enter value # = zones not selected will be off in part set etc etc no i just look in the lid where the programming info card is.......................................................... (or used to be on the older ones!) p THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
Guest anguscanplay Posted March 5, 2007 Posted March 5, 2007 no i just look in the lid where the programming info card is.......................................................... (or used to be on the older ones!)p yeah but how good do i look if front of the customer helps them to forget the alarm has gone off again at two in the morning
stewymac Posted March 5, 2007 Posted March 5, 2007 anyone want to know the programming for a 9100zone number enter 6 enter value 0 = zones not selected will be off in part set etc etc your wasted with that talent...
stewymac Posted March 5, 2007 Posted March 5, 2007 even went back to one after twelve years plus and told them there code number dont tell me..it was EDITED FOR PRUDENCE....classic service engineer trick...
black knight Posted March 5, 2007 Posted March 5, 2007 yeah but how good do i look if front of the customer helps them to forget the alarm has gone off again at two in the morning AS THIS STRAYS INTO ENGINEER FUNCTIONS - CONTENTS REMOVED BY ARFURIf ones (ancient) memory is working that particular model EDIT to access engineer functions anyway!! PS moddies - I,m surprised you havn't this yet!!!! paul JOB DONE - ARFUR THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
black knight Posted March 5, 2007 Posted March 5, 2007 dont tell me..it was wrote on the back of the lid....classic service engineer trick.. CONTENT REMOVED FOR SECURITY PRUDENCE REASONS - BU ARFUR and you did a sheer luck holmes and guessed them in the right order (done both incidentally) (seen that more than once) and in (old ) days even had key hung on a piece of string alongside panel - when asked customer why they said it saved having to hunt for the key on coming in!! (when i explained it made life easier for burglar as well it was removed PDQ!! :'( ) paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
stewymac Posted March 5, 2007 Posted March 5, 2007 nope just cursed with a memory ive had a problem with a 9100 it sometimes sets instantly...not all the time tho and the call engineer light flashes when i put the engineer code in..
Guest anguscanplay Posted March 5, 2007 Posted March 5, 2007 ive had a problem with a 9100 it sometimes sets instantly...not all the time tho and the call engineer light flashes when i put the engineer code in.. i shouldnt but what the hell the call engineer light means you have got something on soak test setting imediatly has it got a chubb lock on it check prog 51 if not
stewymac Posted March 5, 2007 Posted March 5, 2007 i shouldnt but what the hellthe call engineer light means you have got something on soak test setting imediatly has it got a chubb lock on it check prog 51 if not it hasnt got a chubb lock
