Guest anguscanplay Posted March 5, 2007 Posted March 5, 2007 it hasnt got a chubb lock part set or full set or both
magpye Posted March 5, 2007 Posted March 5, 2007 ive had a problem with a 9100 it sometimes sets instantly...not all the time tho and the call engineer light flashes when i put the engineer code in.. I think you will find that means that there is a circuit 'on test ' Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
Guest anguscanplay Posted March 5, 2007 Posted March 5, 2007 too slow right check lock set isnt linked out in panel more likely check final door set isnt seing a pir on the way to set the panel so setting when relay throws faulty press to set button
stewymac Posted March 5, 2007 Posted March 5, 2007 faulty press to set button ill have a look at the pts if it happens again....thanks
Guest anguscanplay Posted March 5, 2007 Posted March 5, 2007 ill have a look at the pts if it happens again....thanks seriusly? i thought we were playing a game have you got a pts damm should have told you my callout charges first right who`s next
