Homesafe1 Posted March 4, 2007 Posted March 4, 2007 JUST AFTER SOME ADVICE , JUST ABOUT TO INVEST IN SOME NEW TEST EQUIPMENT FOR TESTING ALARMS, I THINK IM GOIN TO BUY THE C3G KIT FROM ACT, WHICH INCLUDES A GOOD MULTIMETER, CA60 mA CURRENT CLAMP, BATTERY TESTER AND IT COMES IN A HARD CASE, DOES ANYONE NO OF ANYHING BETTER COSTING NO MORE THAN
stewymac Posted March 4, 2007 Posted March 4, 2007 JUST AFTER SOME ADVICE , JUST ABOUT TO INVEST IN SOME NEW TEST EQUIPMENT FOR TESTING ALARMS, I THINK IM GOIN TO BUY THE C3G KIT FROM ACT, WHICH INCLUDES A GOOD MULTIMETER, CA60 mA CURRENT CLAMP, BATTERY TESTER AND IT COMES IN A HARD CASE, DOES ANYONE NO OF ANYHING BETTER COSTING NO MORE THAN
stewymac Posted March 4, 2007 Posted March 4, 2007 But is the new meter calibrated ? it should be,,hence the worthless bit of paper that say so...keeps nacoss happy tho...i mean after a year of decent use the meter is srcatched,dented,leads bent etc,why pay for cali when you can buy a new meter,unless you have a top fluke with all the features you dont need or use...
Service Engineer Posted March 4, 2007 Posted March 4, 2007 battery testers cost more than that unless its a dodgy one or something. Make yourself a drop tester, they give a much better indication of true battery condition. ........................................................ Dave Partridge (Romec Service Engineer)
stewymac Posted March 4, 2007 Posted March 4, 2007 battery testers cost more than that unless its a dodgy one or something. do a google,cheap as..dont use one myself ...load test with meter,give it a shake to check for loose cells,good mains fail test fine leave it.....
Guest Posted March 4, 2007 Posted March 4, 2007 Last time i drop tested a 17ah i almost broke my toe, always wear PPE I say
