Lilliput Touch Screen
luggsey
I tried to make my Lilliput touchscreen monitor work with a small CCTV camera and it dosent want to know?
Works fine on 1v pp signals but not on my cameras no matter what input mode I use (NTSC/all pall/secam etc. nothing works)
Any ideas?
My Amateur Radio Forum
Guest anguscanplay
because its you luggsy i am going to ignore the rule about if you have no idea keep quite
i have no idea
is the monitor vga
i have no idea
is the monitor vga
Yep, does every blooming thing, except work with a low res camera!
I was going to buy a good spec reverse camera but wanted to suss out why it dosent work on a cheapo one first.....
Guest anguscanplay
Any ideas?
what is it
what is it
Lilliput
tell me what you have done so far
Tested it with my DVD/MP3 car head unit on both inputs and it's fine. Test it with a cheap camera that has a scart output and nothing at all whatever mode I try?
Guest anguscanplay
you have confirmed the camera havnt you
check the scart to video adapter is it an in or an out one
Yes! Works fine, thats what foxs me, must be the res/TTL of the camera of something?
Guest anguscanplay
describe the scart to video adaptor to me how many pins has it got
