Lilliput Touch Screen
luggsey
Guest anguscanplay
  uski said:
Remove polarisation if any. Sometimes manufacturer like to rely on "the other one" to use this capacitor because it takes a lot of room.
As a result if you're unlucky you have two devices where they rely on the other one and... it doesn't work.
It already happened to me several times especially with cheap chinese USB video acquistiion devices and cheap cameras :)
:sofa1:
  luggsey said:
Did u see my other post? I found the monitor will not resolve black and white cameras.
Any idea how to get the monitor to "see" a black and white signal?
Doh ? This is strange; where did you read that your monitor doesn't support B&W video ?
  jameswilson said:
it might be looking for the colour burst
Didn't think of this one, well done
Guest anguscanplay
have to connect some old b/w mains cameras to a dvr for a customer could i have the same problem
Guest anguscanplay
  jameswilson said:
your problem is that b/w is a standard called CCIR and colour is PAL. If your dvr only accepts pal then you might, but unless it the nastiest of the cheap it should have a mono input setting
never let it be said that i hanvt learnt something new thanks
