kcbabi Posted March 5, 2007 Author Posted March 5, 2007 Here is a User Guide, use the Walk Test facility to identify your circuits, good luck.By the way, as you asked, you will have to 'Omit' the troublesome circuit every time you 'Set' the system, to do this on a more perm. basis will require an engineer. 9448_User_Guide.pdf fella, much appreciated user manual attached, walk test= 5, enter, code. to stop walk test put your code in. fella - off to solve me problem!!! I'm only 24 so I havent come across these much on install but I'm not so sure about the 9448 - I thought it was more like 9452's, if you find the main control panel in the loft of cupboard that will give you a better clue as to what panel you have. thanks for yuor help mate - much appreciated
