marvellousdobby Posted March 5, 2007 Posted March 5, 2007 I have a problem setting my Gardtec alarm system. It has recently come up with the message En instead of the usual Un message. When I set the system it seems to have set but it does not. Instead after pressing yes Ac comes on the disply and 4 digits appear. It then goes back to En. I have looked in the user instructions but it does not say what to do. Can anyone please help. Thankyou.
Guest anguscanplay Posted March 5, 2007 Posted March 5, 2007 I have a problem setting my Gardtec alarm system. It has recently come up with the message En instead of the usual Un message. When I set the system it seems to have set but it does not. Instead after pressing yes Ac comes on the disply and 4 digits appear. It then goes back to En. I have looked in the user instructions but it does not say what to do.Can anyone please help. Thankyou. the system is looking for an engineer reset probably because the service timer has kicked in it maybe that the installer has enabled this feature but only the original installer can remove it if you are under warrenty or due for a srvice visit now is the time to call them if they want to charge you to remove the setting pm me
marvellousdobby Posted March 5, 2007 Author Posted March 5, 2007 the system is looking for an engineer reset probably because the service timer has kicked in it maybe that the installer has enabled this feature but only the original installer can remove it if you are under warrenty or due for a srvice visit now is the time to call them if they want to charge you to remove the setting pm me Thanks I will give them a ring tomorrow.
Guest anguscanplay Posted March 5, 2007 Posted March 5, 2007 Thanks I will give them a ring tomorrow. till marvellousdobby returns i know the 300/500 too well
marvellousdobby Posted March 10, 2007 Author Posted March 10, 2007 Thanks for your help. My alarm supplier unlocked the service timer engineer mode.
Guest anguscanplay Posted March 10, 2007 Posted March 10, 2007 Thanks for your help. My alarm supplier unlocked the service timer engineer mode. your welcome
