Ginger Posted March 7, 2007 Posted March 7, 2007 Hello all, Firstly I apologise if this is a subject that has been discussed/answered before, but after looking though these forums I can
Guest Posted March 7, 2007 Posted March 7, 2007 tamper feed requires a link from neg if i recall right
Guest anguscanplay Posted March 7, 2007 Posted March 7, 2007 Hello all,Firstly I apologise if this is a subject that has been discussed/answered before, but after looking though these forums I can
kka Posted March 7, 2007 Posted March 7, 2007 is your outside sounder a 'Pyronix belle' if so there need to be a wire going from b- to tf. then 5 wires coming back to the panel B- to bell - B+ to bell + BA to N/O bell STB to N/O strobe BT to Bt Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
arfur mo Posted March 7, 2007 Posted March 7, 2007 hi ginger, safety is the 1st off the blocks. very careful and respectful of the high voltages present when the strobe is operated, as they can cause a severe shock of several thousand volts and subsequent burns if you get in contact with them while operating. also while at the sirens, a sudden unexpected operation could startle you and cause an accident. my initial thought is have you programmed the external sirens as SAB not SCB? if not go back and change the setting. you mention 2 external sirens, can i suggest you disable the rear one and get the front siren operating properly first, trust me, getting 2 to operate properly has taxed many an experienced engineer, if this forum is anything to go by . the sirens will 'ring' in to ways -: 1) from the on-board battery in the absence of a hold of voltage from the controls. 2) a negative applied from the panel. the strobe is also operated by a separate negative from the panel. with the above in mind, having disconnected the rear siren ensure you have the 'hold off' voltage present on the correct terminals at the front siren, refer to your drawings supplied with it and apply a negative to the wire you used, this should sound the siren. if it works then great, reconnect it to the panel pcb and test. do same test for strobe. if you have probs with second siren post back here regs alan If you think education is difficult, try being stupid!!!!
kka Posted March 7, 2007 Posted March 7, 2007 is your outside sounder a 'Pyronix belle' if sothere need to be a wire going from b- to tf. then 5 wires coming back to the panel B- to bell - B+ to bell + BA to N/O bell STB to N/O strobe BT to Bt please feel free to shoot me,this info is not quite correct if two belle's are being used sorry. must learn to read, very quickly ...... sorry Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Ginger Posted March 7, 2007 Author Posted March 7, 2007 Hello, Very speedy replies, thank you to everyone that has taken the time to help so far, my sanity and I appreciate it. In response to some of the points raised: Both bells are indeed the
arfur mo Posted March 7, 2007 Posted March 7, 2007 Hello,Very speedy replies, thank you to everyone that has taken the time to help so far, my sanity and I appreciate it. In response to some of the points raised: Both bells are indeed the If you think education is difficult, try being stupid!!!!
amateurandy Posted March 7, 2007 Posted March 7, 2007 so my strongest advice is get it working on the front siren alone, prove the system is reliable Based on comments I've seen many times that is excellent advice to a DIY-er. From what I've seen in these forums it is considered "normal practice" to only have 1 working external siren on a "bells only" domestic installation, with any additional unit being just a dummy, or with just LED's flashing to be visible at night. So I would give up on making the second unit sound, though if you've got the wiring in you might as well leave the LED's running. As noted earlier, getting a second siren working can be quite tricky and it doesn't really add anything - so the professional's say and I believe them.
arfur mo Posted March 7, 2007 Posted March 7, 2007 Based on comments I've seen many times that is excellent advice to a DIY-er. thanks 'son' now can you have a pocket money increase now? regs alan If you think education is difficult, try being stupid!!!!
