Vinny1684 Posted March 8, 2007 Posted March 8, 2007 Good afternoon guys, Well my previous post that had to get deleted due to me posting some factory codes (sorry) has all been sorted, im now with the codes i want. Now when i goto bed, i want to part set the house, there is only 3 zones. 2 downstairs and 1 upstairs. Zone 1 and 2 are downstairs and Zone 3 is upstairs, How do i step by step part set the house so only zone 1 and 2 are active? Thanks
breff Posted March 8, 2007 Posted March 8, 2007 also 21-2 on prog, 22-nothing on prog, 23-nothing on prog, assuming 2 is a pir and 1 is the door contact. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest anguscanplay Posted March 8, 2007 Posted March 8, 2007 i dont understand that and i am an experienced installer remember guys it took a while to explain the codes and i never got the girl ( no disrespect vinny 1684)
breff Posted March 8, 2007 Posted March 8, 2007 i dont understand that and i am an experienced installerremember guys it took a while to explain the codes and i never got the girl ( no disrespect vinny 1684) I know , but we cant really elaborate more in public. TBH the OP could ring Texecom Support, the number is on the manual IIRC The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest anguscanplay Posted March 8, 2007 Posted March 8, 2007 I know , but we cant really elaborate more in public.TBH the OP could ring Texecom Support, the number is on the manual IIRC very true
Vinny1684 Posted March 8, 2007 Author Posted March 8, 2007 very true Ah but if i rang texicom... it would keep u guys from being busy on the forums I have no door contacts, just the sensors, 1 in living room, 1 in dining room and 1 on stairs landing, i want to knock the stairs one off...
Guest anguscanplay Posted March 9, 2007 Posted March 9, 2007 i understand that perfectly whats the issue??? dear cjt please could you explain to the delightfull vinny1684 how to set the part sets on his system without giving the actual programme string but more in the line of you need to select the option that will etc we managed to clear up his code programming before the post was pulled unfortunatly there was too much info posted
Vinny1684 Posted March 9, 2007 Author Posted March 9, 2007 Its ok, i read the book and figured a way i could do it, Put in code Press FULL Press Omit Select Zone i want to keep off (zone 3) Press Program Walah anyhoo!
breff Posted March 9, 2007 Posted March 9, 2007 If you do that when you go downstairs and trip a detector it will go into full alarm. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
