notrevo Posted March 9, 2007 Posted March 9, 2007 Hello. I'm connecting the Intellisense AG8 External Sounder & strobe to my Sterling 10 panel. Tech Support at Intellisense seemed vague with their response to my question: "Erm... try this and maybe that..." Sterling 10 isn't listed under 'Connections' in the Intellisense Instn booklet, so I'm seeking assurance from people who know, to be 100% certain. What do I connect to what please? AG8 has R- V- ST- V+ -SW STERLING 10 has Bell+ Bell- BT Bell NO Bell C Bell NC STROBE NO STROBE C STROBE NC Regards, Notrevo
black knight Posted March 9, 2007 Posted March 9, 2007 Hello.I'm connecting the Intellisense AG8 External Sounder & strobe to my Sterling 10 panel. Tech Support at Intellisense seemed vague with their response to my question: "Erm... try this and maybe that..." Sterling 10 isn't listed under 'Connections' in the Intellisense Instn booklet, so I'm seeking assurance from people who know, to be 100% certain. What do I connect to what please? AG8 has R- either neg return or neg ring V- supply neg ST- strobe neg V+ supply pos -SW ring neg? in which case 1st one is neg return STERLING 10 has Bell+ supply Bell- supply BT tamper return Bell NO Bell C bell o/p Bell NC STROBE NO STROBE C strobe o/p STROBE NC Regards, Notrevo Not knowing the sterling or the SAB personally the above is a guess. the finer points of connections i presume you will know. If not i recommend you get a pro. in. p THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
Guest Posted March 9, 2007 Posted March 9, 2007 Paul's turn to be picked on Bell NOBell C bell o/p Bell NC STROBE NO STROBE C strobe o/p STROBE NC NC,C,NO sounds like a relay output..... C (common require a - feed) move wires to NO termials
black knight Posted March 9, 2007 Posted March 9, 2007 Paul's turn to be picked on NC,C,NO sounds like a relay output..... C (common require a - feed) move wires to NO termials i would agree - read my post the finer points of connections i presume you will know. If not i recommend you get a pro. in. - the part in red in the original post was / is supposed to encompass all three connections. I did,nt want to go in to the finer points of connections until the mods had decided if i was saying too much anyway! paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
Guest Posted March 9, 2007 Posted March 9, 2007 I did,nt want to go in to the finer points of connections until the mods had decided if i was saying too much anyway! shoot I thought I'd got one over you
black knight Posted March 9, 2007 Posted March 9, 2007 shoot I thought I'd got one over you better luck next time (should,nt be that hard ) paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
kka Posted March 9, 2007 Posted March 9, 2007 Sterline 10 panel Strobe N/O Strobe C Strobe N/C Bell N/O Bell C Bell N/C BT Bell - Bell + Link Bell - to Bell C then to Strobe C panel ready use five wires to bell box: Bell -, Bell +, BT, Bell N/C and Strobe N/C hope this helps. sorry with out the connection for your bell box i cannot help any further, can you post them please Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
notrevo Posted March 9, 2007 Author Posted March 9, 2007 ...Thanks gents for those speedy replies. KKI says - Hope this helps. sorry with out the connection for your bell box i cannot help any further, can you post them please The AG8 Bellbox has five terminals: R- Negative Tamper return V- ST- Negative Strobe Trigger V+ -SW Negative Sounder Trigger Regards, Notrevo
kka Posted March 9, 2007 Posted March 9, 2007 this is how i would wire this, R- negative tamp rtn to BT ST- Negative strobe trigger to N/C Strobe SW- Negative sounder trigger to N/C Bell V- to Bell - V+ to Bell+ if you have any problem please let us know. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Alarm Co Posted March 9, 2007 Posted March 9, 2007 Sterline 10 panel Strobe N/O Strobe C Strobe N/C Bell N/O Bell C Bell N/C BT Bell - Bell + Link Bell - to Bell C then to Strobe C panel ready use five wires to bell box: Bell -, Bell +, BT, Bell N/C and Strobe N/C hope this helps. sorry with out the connection for your bell box i cannot help any further, can you post them please this should be bell n/o and strobe n/o as thaey are switched 0volts
