Menvier Speech Dialler 2
Steve K
Hi Guys,
Anyone tried to program a Menvier SD2 to overcome a call barring code?
I've programmed the number for the code, and as soon as it gets as fars as #34 the number unobtainable tone is received. It is a standard BT line, and the customer keeps call barring on for his son who has a tendancy to run up huge bills. Apart from having call barring permanently turned off, does anyone know of another option? I've tried putting a "," pause in the number, but it still doesn't work.
Thanks
Steve
Steve Kendall
Plymstock Security Systems
Hi Guys,
Thanks
Steve
Have you tried several pauses together?
My Amateur Radio Forum
Yep! Even tried just the first three characters with a pause between - as soon as the 4 is sent NU tone is received. The SD2 dials correctly. as it succesfully dials out with a telephone number including all those numbers contained within the code to remove the call barring, when call barring is not active. The problem only occurs when call barring is active. :hmm:
Steve Kendall
Try Menvier Tech, there was a problem on SD1's calling orange mobiles, think an extra "0" at the start cured it. Can't remember any more then that, loooong time ago!
  • 2 weeks later...
Don't know if it helps but menvier now have the SD3 which can use the pstn line or a GSM with any sim card gsm when call bar on pstn when not ??
www.AllanMoncrieffAlarms.com
