Where To Site The Alarm Box?
help please :unsure:
I live in a semi detached house with the upstairs being a loft conversion. The roof is slated and the gable end wall does not face the front of the plot and is therefore not very visible from the road. If I site the bell box on the front of the house, the only vertical wall space means the box will be only 8 -9 feet off the ground, and therefore more accessible to tampering. Is there any preferred method of mounting the box on the sloping roof, or is my only option to use the less visible gable end wall (two stories high)?
thanks in advance
thanks in advance
Why not have 2? A dummy one and a real noisy one?
There's a thread (maybe several) elsewhere on the ease or difficulty of having 2 live bell boxes on a DIY system. :whistle:
thanks in advance
hi cheekygrommet,
this sounds like a chalet type house, if you must mount the siren low use a metal cased one for added strength, as Andy says you could mount 2 sirens, one front and one rear or one high, at least that way they protect each other to some extent.
regs
alan
Hi, cheekygrommet
why not put the 'real' sounder on the gable end (get a loud one) and an identical looking 'dummy' on the lower front of the house, but, wire a tamper switch to this box so that if it is played with it will activate the system - sorted.
