Drop Prop Alarm
apr400
Hi,
I am looking for an alarm that will go off if a door is propped open. The closest I have found to my needs is the Exit Stopper from STI, but the delay isn't quite long enough. Specifically I would like:
Mains Powered
Reasonably Loud ~ 100 db
Magnetic switch
A delay of around 1 minute after the door is opened before the alarm goes off (but preferably adjustable)
Continuous sounding until the door is closed
Reset on door close
Reasonably vandal resistant.
Anyone know of anything that would fit the bill, in the 100 pound range.
thanks
Alex
Hi,
Mains Powered
Magnetic switch
Reset on door close
thanks
Alex
1x 12v psu metel cased
1x 12v dc delay on timer resolution to suit you ie. 10 seconds to 5 mins adjustable.
1x internal sounder, intruder alarm type 12v
1x flush door contact, intruder alarm type
1x 12 v relay
Suggest a keyswitch overide for when you "need" to have the door open.
These bits should be less then
My Amateur Radio Forum
You can use our ACT10 Keypad, as it has this very feature in it, along with Interlocking, 2 Relay outputs, Tamper, ooo the list goes on.
Have a look t the data sheet
Richard
And a psu and a sounder! :rolleyes: Oh and someone to install it all.
Yes you will need a P.S.U and sounder and if you have a look at our datasheet, it doesn't include the other equipment. So dont forget, you will need a 240 volt supply (Part P qualified Electrician), screws, Raw plugs, Cable, dare i go on LOL :no:
Regards
Richard
www.accesscontrol.ie
richard.huison@accesscontrol.ie
ACT "Where performance counts"
"Is your Access Control system Vista Ready?"
Many thanks for all the replies.
The ACT looks very nice - but probably a little complex for our needs what with all the extras needed.
HED Solutions Model EX206 seems to meet our needs and is all-in-one.
I have a tame Electrician on staff!
Thanks all
Alex
Thanks all
Alex
Do get your local alarm company to have a look as well, there is every chance your intruder alarm panel can be set to activate an internal alarm on 24 hour setting via a delay.
You did blow your
And he's called 'The Stig'
