origipolo Posted March 15, 2007 Posted March 15, 2007 Hi there, I recently installed the Aritech CS450. I have 1 keypad attached (CD3008) attached at the moment. Each time I power up the panel the keypad emits a chirp and 'nd - no panel data' is displayed. None of the leds on the panel light up. When I press any button on the keypad the chirp stops. I have checked the wiring (red, black, blue, yellow) all correspond to ABCD->19,20,21,22. I have tried all dipswitch settings.... I still get the same error ??? Can anybody help me out here, any suggestion would be gratefully appreciated... Thank you, Origipolo.
morph Posted March 15, 2007 Posted March 15, 2007 Have you spoken with the supplier of the equipment as they are best placed to support the equipment.
origipolo Posted March 15, 2007 Author Posted March 15, 2007 No I didn't, I figured it out myself in the end
Guest Posted April 29, 2007 Posted April 29, 2007 origipolo, how did you fix it? I have the same issue, but my "secteur" green LED is on thanks for any help secureart
camerabloke Posted April 29, 2007 Posted April 29, 2007 i would say hes not coming back now! secureart. have you tried a restart on the panel Eucam Security Systems 0845 4630 746 www.eucam.co.uk
morgan306 Posted April 29, 2007 Posted April 29, 2007 I would first double check the address of the keypad, should be all dip switches in the off position, and then check cable between panel data and keypad. I have been using Aritechs for years, and have only ever seen that message once (Because I had wired the data line round the wrong way like a fool!)
