Port Forwarding
Russ
hi i need to set a bt 2wire router to port forward, for remote access to a samsung dvr. The dvr uses ports 554 - 557. I've put the machine onto a local network but obviously i cannot login via internet.
Can someone help?
cheers
RussellMorris
www.securesolutions.org.uk
Can someone help?
cheers
RussellMorris
hi Russ,
if you phone BT help from the site they may remote in and do it for you, if not google 'port forwarding' and you will get to a page showing you how.
regs
alan
Can someone help?
cheers
RussellMorris
Hi Russ,
Do you have an external Static I.P address?, if not have a quick read at these posts:
http://www.thesecurityinstaller.co.uk/comm...mp;#entry158058
Loads of help on port forwarding here:
http://portforward.com/routers.htm
Can someone help?
cheers
RussellMorris
Port forwarding is usually pretty simple to set up, so can you explain a bit more what your problem is?
e.g. No manual
Manual doesn't explain how to do it
Can't understand the manual
Don't understand port forwarding
Can't get into router admin menus
etc.
2wire has a good online support section with all the manuals in and much more at www.2wire.com :rolleyes:
There are also some links (use search) elsewhere in this forum to web pages describing the overall process for setting up access to DVR's in this scenario.
  • 1 month later...
Port forward 554-557 on TCP
8000 - 8159 on UDP
if you bought the Samsung SHR2162P or SHR2042P DVR from Aasset Security, they are the official UK (and Europe) importer of the Samsung Electronics DVRs - ring their tech support on 01908 230830 or 0845 2308330
You will need the serial number of the unit on the left hand side begins 6VSPxxxx
BT tech support can set this up but wont if you tell them its for a DVR! Also avoid DMZ as this does not work particularly well with this router and DVRs.
TSS
Communication is "A question asked, and an Opinion given." I offer mine to help you with yours.
Statements I make are my personal views only at the time they are posted, if I offend you sorry, must be taken in context and do not neccesarily represent those of my employer.
Forgot to mention, change the remote management port of the router to something like 51003 as it is then outside the port range used by the DVR
Also, in my experience most problems are caused by the router's firewall or incorrectly configured services
Make sure that each service is correctly configured for inbound and outbound traffic
best of luck
TSS
Can someone help?
cheers
RussellMorris
Hi, IIRC on the 2-wire you get into admin in Internet Explorer through http://ip_address_of_router/management
Then in FIREWALL you can set the the ports to forward to specific network devices. When I forwarded ports to our email server, I'm sure the 2-wire scans the local area network and identifies the PC's. DVR, etc by their MAC address.
On a PC you find the MAC address by typing ipconfig/all at a command prompt. On a DVR it's probably somewhere in the on-screen set up function or on a sticker on the outside of the unit.
I found the CD-ROM & BT user guide that came with my 2-wire router absolutely useless and I had to download the proper installation guide and user guide from 2wire themselves. I've got them as PDF's - PM me your email address if you want them
Jacko
Jacko
Yes mac address on LHS of unit on a silver sticker, beneath the bar code
TSS
TSS
