Guest fabsy Posted March 10, 2004 Posted March 10, 2004 NEED HELP PLEASE. I JUST PURCHASED A NEW HOME AT IT HAS A CADDX DL200 ALARM SYSTEM. I WANT TO CHANGE THE ALARM CODE BUT GOT NO IDEA HOW TO DO IT. DOES SOMEONE OUT THERE HAVE THE MANUAL FOR THIS BEAST OR CAN TELL ME HOW TO CHANGE THE CODE PLEASE
Service Engineer Posted March 11, 2004 Posted March 11, 2004 This is all I can find on anything to do with codes but the information is for the DL250, so the information below may be of no use to you. LOCATIONS 000-003: PROGRAMMING THE MASTER ARM/DISARM CODE Locations 000-003 contain the master arm/disarm code (user number 1). Location 000 contains the first digit of the code; location 003 contains the fourth digit of the code. THE CODE MUST CONTAIN FOUR (4) DIGITS. The master code can then be used in the RUN mode to enter arm/disarm codes 1 - 15. The factory default code is [1][2][3][4]. LOCATIONS 004-055: PROGRAMMING THE ARM/DISARM CODE FOR USERS 2 THROUGH 14 Locations 004-055 contain the arm/disarm codes for users 2 through 14. To program these codes, follow the instructions in the paragraph above. To disable these codes, program a "15" (factory default) as the first digit of the code. These codes can be changed in the RUN mode using the master code (refer to operator's manual). LOCATIONS 056-059: PROGRAMMING THE ARM/DISARM CODE FOR USER 15 (DURESS CODE)Locations 056-059 contain the arm/disarm code for user number 15 (Duress Code). To program this code, follow the instructions in the paragraph above. This code can be used as a duress code if so programmed in locations 288 - 291. Factory default for this code is "15", disabled. ........................................................ Dave Partridge (Romec Service Engineer)
