Ish Posted March 16, 2007 Share Posted March 16, 2007 Hi which UPS would you recommend to run 3 dvr's? Link to comment Share on other sites More sharing options...
Alpat Systems Posted March 16, 2007 Share Posted March 16, 2007 Hiwhich UPS would you recommend to run 3 dvr's? Hi Ish, You need to be a bit more specific i.e Which DVR's, (need to know power usage) How long do you require the UPS to run on battery following a power outage? Rackmount or Free standing Is power fail alert required etc etc....... I've always used APC products (www.apc.com) some of the UPS do alot more than just battery backup! Link to comment Share on other sites More sharing options...
Ish Posted March 16, 2007 Author Share Posted March 16, 2007 Hi Ish,You need to be a bit more specific i.e Which DVR's, (need to know power usage) How long do you require the UPS to run on battery following a power outage? Rackmount or Free standing Is power fail alert required etc etc....... I've always used APC products (www.apc.com) some of the UPS do alot more than just battery backup! dvrs are system q's 16ch dvr365 up to 12 hours battery life would be good free standing preferred power fail alert not needed thanks Link to comment Share on other sites More sharing options...
uski Posted March 16, 2007 Share Posted March 16, 2007 Hi, I assume that you also want the UPS to supply battery power to the cameras and other devices if any ? You first need to determine how many Watts all this stuff eats... 12 hours is quite long for an UPS and expect the UPS to be quite bulky and heavy. uski Link to comment Share on other sites More sharing options...
Ish Posted March 16, 2007 Author Share Posted March 16, 2007 we just want the ups to power the dvr's. Link to comment Share on other sites More sharing options...
cutwitt Posted March 17, 2007 Share Posted March 17, 2007 we just want the ups to power the dvr's. The 365 needs 65 watts so to keep 3 running for 12 hours you will need a 2200VA UPS It will weigh around 60 Kg and set you back around Link to comment Share on other sites More sharing options...
Alpat Systems Posted March 17, 2007 Share Posted March 17, 2007 Run time charts: http://www.apc.com/products/runtime_for_ex...m?upsfamily=165 Link to comment Share on other sites More sharing options...
cutwitt Posted March 17, 2007 Share Posted March 17, 2007 Ignore my last post - online runtime calculator is //.B.W.F.//*d You need something a bit bigger APC SU2200XLINET + (2)SU48XLBP would give you 10 hours Link to comment Share on other sites More sharing options...
Ish Posted March 17, 2007 Author Share Posted March 17, 2007 Ignore my last post - online runtime calculator is //.B.W.F.//*dYou need something a bit bigger APC SU2200XLINET + (2)SU48XLBP would give you 10 hours . i'll check the lonks out as well. Link to comment Share on other sites More sharing options...
kensplace Posted April 6, 2007 Share Posted April 6, 2007 What about the cams? Three 16 channel dvrs, could be max of 48 cams that also need backup power for 12 hours... Plus any telemetry, pan / tilt / zooms, alarms, monitors etc. Link to comment Share on other sites More sharing options...
