Veritas 8c Unset Light On/power Led Constantly Flashing.?
jaimec
Guest anguscanplay
okay worse case senario
you should disconnect one side of the battery from the alarm wiring now but do it carefully - dont t urn off the mains first -
there shouldnt be a too much risk of a shock but the gel leaching out of the battery can be corrosive and definatly keep away from eyes and mouth
i personally would also power down the system due to the burning smell but you may find that once the battery is dissed the panel will start to cool down ( it may be very hot right now) you could check after an hour but any doubt power it down
IF YOU DO POWER IT DOWN THE SOUNDER MAY START OUTSIDE
this should stop after around twenty minutes but i cannot guarentee this if it doesnt you may need an engineer tonight and it WILL cost you
get it repaired and have it serviced annually for exactly this reason they rarely fail at 8.30 on a monday morning
Thanks for the advice - The smell wasn't burning and the system wasn't hot at all, just the smell of the gel leaching out I guess. Had a look and saw that the fuse on the right hand side has blown.
I've disconnected the battery at both terminals and the system appears to be dead now (no Lights or LEDs).
Is it safe to leave like this until I can get an engineer out? Is the alarm likely to go off in the middle of the night?
You mentioned 'power down the system' - how do I do this?
Which seems to indicate that there is no mains supply to the panel
Yes, if it were to go off it would have done when all power was removed, and indicates that your bellbox battery is faulty or not connected
It sounds as if you have done this, to be certain remove the mains fuse in the spur or panel
Hope this helps, does seem like you could benefit from a visit by an engineer to revive it though, especially as the Veritas has a habit of defaulting itself when mains is removed and the battery goes flat
Regards
Glenn
Guest anguscanplay
cheers breff got a little side tracked ahem
have you been working in the house doing diy etc or have you had anyone else in it sounds like a clssic mains reconnect with a duff battery as long as all is quite dont worry tonight but deffinatly look for an engineer to call
dont be tempted to just get a battery from maplins etc it needs to be checked profesionally
