arfur mo Posted June 20, 2007 Posted June 20, 2007 This is a pic of what I found above the false ceiling while I was commissioning a system installed by a subby! another case of a few more seconds and he could have done the job properly, i would be a little verbous as you could immagine towards this twerp. i might also take the time to exsplain to him that most if not all manufacturer's, do not recommend running detection in the same cable as sirens . regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted June 20, 2007 Posted June 20, 2007 i might also take the time to exsplain to him that most if not all manufacturer's, do not recommend running detection in the same cable as sirens .regs alan xxxx are you telling me yet again that ive been doing it wrong for the last twenty years or did you mean to say speakers and data cables
arfur mo Posted June 20, 2007 Posted June 20, 2007 xxxx are you telling me yet again that ive been doing it wrong for the last twenty years or did you mean to say speakers and data cables hi Angus, no matey, for as long as i can remmember it was no bells/sirens (including speakers) to be run in with zone wiring, even conventional CCT wiring zone cables, and way before data ever crept into alarms - i'm talking relays and transistor technomology here. it could cause a false indication, also more for engineers safety. ever touched a 'pair' feeding a ringing internal bell? three cherries and a lots of swearing guarenteed, in a siren with an operating strobe inadvertantly touching the 12 volts supply could actually burn you. regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted June 20, 2007 Posted June 20, 2007 hi Angus,no matey, for as long as i can remmember it was no bells/sirens (including speakers) to be run in with zone wiring, even conventional CCT wiring zone cables, and way before data ever crept into alarms - i'm talking relays and transistor technomology here. it could cause a false indication, also more for engineers safety. ever touched a 'pair' feeding a ringing internal bell? three cherries and a lots of swearing guarenteed, in a siren with an operating strobe inadvertantly touching the 12 volts supply could actually burn you. regs alan time for your medicine again old chap its 12v plain and simple nothing more nothing less the cable would melt before it hurt and the strobe touch the supply - er isolated by the transformer in the external box speakers not good - corrupts data
tinnitus Posted June 20, 2007 Posted June 20, 2007 im working in a little shop installing security at the mo .old trunking running everywhere, not nice. its also quite untidy. the previous owner had left a drum of mains cable in a corner, i thought nothing of it and it wasn't in my way so i didn't touch it. the new owner and my customer was moving sockets and was trying to trace cables from the fuse board, guess where the cable wired into the 30 amp fuse went? that's right, the cooker, only joking it was the drum of cable in the corner, live and 30 amps!
barooga Posted June 20, 2007 Posted June 20, 2007 im working in a little shop installing security at the mo .old trunking running everywhere, not nice. its also quite untidy. the previous owner had left a drum of mains cable in a corner, i thought nothing of it and it wasn't in my way so i didn't touch it. the new owner and my customer was moving sockets and was trying to trace cables from the fuse board, guess where the cable wired into the 30 amp fuse went?that's right, the cooker, only joking it was the drum of cable in the corner, live and 30 amps! It's to stop the scroats nicking it to weigh it in. They'll only try it the once. Growing old is mandatory, growing up is optional
tinnitus Posted June 20, 2007 Posted June 20, 2007 It's to stop the scroats nicking it to weigh it in. They'll only try it the once. thats a good point, i dont know if you were joking but that might be true. hmmmm
arfur mo Posted June 20, 2007 Posted June 20, 2007 time for your medicine again old chapits 12v plain and simple nothing more nothing less the cable would melt before it hurt and the strobe touch the supply - er isolated by the transformer in the external box speakers not good - corrupts data the induced high voltage on 12 volt line from the strobe circuit can actually burn you, it feels like a wasp sting than a jolt, so wonder if it is actuall;y microwaving you fingers :'( the strobe has to be active and you need to touch the wires as it won't 'arc' to you, not that i'd recommend anyone try it out for themselves. regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted June 21, 2007 Posted June 21, 2007 the induced high voltage on 12 volt line from the strobe circuit can actually burn you, it feels like a wasp sting than a jolt, so wonder if it is actuall;y microwaving you fingers :'( the strobe has to be active and you need to touch the wires as it won't 'arc' to you, not that i'd recommend anyone try it out for themselves. regs alan only part on an active strobe thats remotly dangermouse is the metal " band" that encircles it - ie behind the bellbox cover - and then you need to be up around the 500v dc mark to feel anything you implied that the cables feeding the sounders were " hot " now phone cables are a different bag of fish - ac ring volts whilst stripping them with your teeth anyone ?
TSS Posted June 21, 2007 Posted June 21, 2007 a friend of mine put a home highway lead into mouth when trying to pass it through a hole in a shelf... tiongue went numb for ages i'm told TSS Communication is "A question asked, and an Opinion given." I offer mine to help you with yours. Statements I make are my personal views only at the time they are posted, if I offend you sorry, must be taken in context and do not neccesarily represent those of my employer.
