Garden Alert
HELP! IVE JUST INSTALLED A TEXECOM SYSTEM FOR MY CUSTOMER AND HES ASKING IF IT WOULD BE POSSIBLE TO HAVE A SENSOR OR SOMETHING IN THE GARDEN AND WHEN ITS ACTIVATED FOR A STROBE TO FLASH IN HIS BEDROOM. WHAT DO YOU THINK ? HE GOT BURGLED AND NOW HES EXTREMLY SECURITY CONSCIOUS SO I SAID ID LOOK INTO IT FOR HIM.......
ALSO IVE INSTALLED A VERITAS R8 SYSTEM AND NOW HES DECIDED HE WANTS THE ALARM TO TELL HIS MOBILE WHEN IT GOES OFF, TO BE HONEST I HAVENT ACTUALLY INSTALLED A VOICE DIALLER BEFORE SO CAN THIS BE ADDED TO MY R8 SYSTEM IVE INSTALLED (PLEASE HELP)
Guest anguscanplay
i wouldnt go there in the garden front fit him a gjd lighting/sensor system instead its designed for the job
angus
Hi there. We currently use the Risco WatchOut Range for external/outside protection we haven't had any problem with them yet and they do have an excellent catch performance. They ignore things like swaying trees and animals. But you must read the instructions that comes with it about installing it. As for texting or speech diallers we use the Texecom speech diallers which depending which models you choose you can have text and also add RMU (remote microphone units) so you can listen in.
Here's some links
Risco Watchout Detector
Texecom Speech Dialler
Hope These Help
Here's some links
Hope These Help
cheers IM LOOKIN IT UP NOW
hi, advice only. the use of capital letters in your script is considered 'shouting' :yes:
Guys Lighten Up :punk:
Dialers are quite easy to fit, they are triggered by the sw -ve same as the bell and just need to be wired into a phone socket.
Normally the most difficult thing about them is getting to the nearest phone point.
Always make sure the point works before you start.
The ADE Informa is cheap and chearfull but Texecom do a speech and text dialler which looks a lot more modern, has extra features and probably explains in the instructions how to wire into the R8, same manufacturer.
All dialler instructions are pretty good so buy one and get it working at home instaed of struggling on the job.
I wouldn't recommend connecting an external sensor to your intruder alarm!
A floodlight with built in PIR and an RF transmitter to a switched output is best. This might sound a bit complicated but it doesn't have to be.
Check ou the products below.
TLRXC1 RF Plug-In Chime Alarm Adaptor - chimes when the PIR is triggered and anything plugged in can be activated, like a light etc
TLTX500B 500W RF Multi-PIR Halogen Floodlight - lights up the area and sends a signal to the chime
Hope this all helps!
Thanks for the advice, got the job booked in for friday so im gunna have to make a desicion pretty sharpish on what to do!!!!
Guest anguscanplay
which job is booked in for friday?
